fretboard radius and string height
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=21084
Author:  Heath Blair [ Tue Feb 17, 2009 12:27 am ]
Post subject:  fretboard radius and string height
or are the two even related? i just hand sanded a 20" radius into a fretboard with a radius caul (i will definitely be using a different method next time) and in doing so i managed to sand the bass side down about .010" to .015" lower than the treble side. i figured id just go back out and fix it, then i thought maybe id leave it. other than looking a bit caddywompus if you sight down the fretboard, would there be any advantages/disadvantages to leaving it this way? this is my first guitar by the way.
Author:  jfmckenna [ Tue Feb 17, 2009 9:59 am ]
Post subject:  Re: fretboard radius and string height
No worries and in fact this is often done on classical guitars. Let me guess, you sanded the board from one side and in one direction only? ;)
Author:  Heath Blair [ Wed Feb 18, 2009 1:30 am ]
bingo. i was really mindful to keep even pressure and make sure to sand the entire board evenly, but to no avail. fortunately not a big deal to fix. thanks for the responses.
not quite sure how to deepen fret slots on a bound board. i dont know if that will be necessary in this case, but any help along those lines?
Author:  jfmckenna [ Wed Feb 18, 2009 9:50 am ]
Very very carefully :)
Edit - woops deleted because I misunderstood
Not sure how to answer that. Perhaps a dremel jig set up...
